12-29-2012 09:33 PM
How do I shoot RAW on card 1 and Jpeg on card 2?
12-29-2012 09:56 PM
12-30-2012 07:16 AM
Have read p116-120 of manual. Is the following correct? If on 'standard' then can record on either card one or card two, but have to have the same image quality? I am going overseas in one day and want to shoot raw on card one only and Jpeg on card two only. So then I can choose before I shoot either card one or card two depending if I need RAW or jpeg.
12-30-2012 08:47 AM - edited 12-30-2012 09:04 AM
Part 1 - set recording option
1. Go to the Set-up (yellow) menu 1
2. Select "Record func + card/folder sel"
3. Select "Record func" (it will probably say "Record func. Standard")
4. Scroll to 3rd option "Rec. Separately"
5. Press select, then Menu twice
Part 2 - set recording type and quality
1. Press the Q button on the back of the camera
2. Scroll to the lower right (using joystick) and select the file type listed for card 1. Press the set button
3. Choose the file type by using the main control dial. Press set to select
4. Scroll down and select the file type for card 2. Press the set button
5. Again, use the main control dial to select the desired file type then press the set button
Now when you display your settings on the rear LCD (press the info button), you should see both cards listed with the desired file type next to it.
Example
Card 1 = RAW
Card 2 = icon for Large JPG
Note: you can do either part through the menus or either part through the rear screen. Also if you choose to use both cards for RAW (so you have a back of each picture as you take them), make sure both cards are HQ with fast write speeds. I use Sandisk Extreme Pro in both of my slots.
EDIT:
Just reread your post. If you want to pick and choose either RAW or Jpg as you take photos, then the procedure above will not do exactly that. The procedure above will always record a RAW copy plus a Jpg copy. Personally that is what I would do, then when you get home you can pick which copy you want to keep.
If you want to pick and choose the file type just before you take a photo, change the recording option to use card 1 first then switch to card 2 when card 1 is full:
4. Scroll to 2nd option "Auto switch card"
Prior to taking a photo...
2. Scroll to the lower right (using joystick) and select the file type listed (both cards now show the same)
4. Take the photo
For this setting your rear LCD will list the same file type for both cards.
Example
Card 1 = RAW
Card 2 =RAW
Good luck and enjoy your trip.
