02-22-2024 07:44 PM - edited 02-22-2024 10:30 PM
I ordered the w-e1 wi-fi converter. I realized I needed to update the firmware. After doing so, the wi-fi still didn't work I didn't know if there was a way to test it to see if it worked elsewhere, but I took it out and put the memory card from that slot back in. Only after this did I realize the SD card slot wasn't reading ANYTHING.
So, the secondary problem would be getting the wi-fi adapter working. But first... is there some way to restore the SD slot? I couldn't find a way to restore previous firmware versions.
*Will update OP with details I've neglected.
Camera is EOS 5Ds.
Not 100% certain what firmware came with the camera. I don't think I updated it after purchasing. It seems like it was definitely 1.0.[something]. It is now loaded with 1.1.4 firmware.
02-22-2024 09:47 PM
Which 5D do you have? Original? Mark II, III, IV?
02-22-2024 10:25 PM
My typo -- Eos 5Ds.I will edit the OP.
02-22-2024 09:52 PM
Hello, TallMisterHall, and welcome to the forum!
Which EOS 5D do you have? EOS 5DS and EOS 5DS R?
BTW, I went to school with a guy named Paul Hall and he was tall, so his nickname was Tall Paul Hall 🙂
Newton
02-22-2024 10:26 PM
In my haste, I guess I omitted that originally. It's a 5Ds.
02-22-2024 11:15 PM
Thank you for the reply. For those that don't know, only three cameras can use the W-E1. I have the card, but used it in my 7D mark II.
Your situation is indeed a puzzle, but hopefully, we can figure it out. There may be a bent pin or some debris in the slot, so shine a light in there and see what you think.
Newton
02-23-2024 12:31 AM
I started noticing, whether it was the adapter or regular sd card, the spring action isn't like it was... I do have some experience with electronics. I wonder if it's worthwhile to open the unit up and look around.
