EOS 5Ds stopped reading SD card slot
TallMisterHall
I ordered the w-e1 wi-fi converter. I realized I needed to update the firmware. After doing so, the wi-fi still didn't work I didn't know if there was a way to test it to see if it worked elsewhere, but I took it out and put the memory card from that slot back in. Only after this did I realize the SD card slot wasn't reading ANYTHING.
So, the secondary problem would be getting the wi-fi adapter working. But first... is there some way to restore the SD slot? I couldn't find a way to restore previous firmware versions.
*Will update OP with details I've neglected.
Camera is EOS 5Ds.
Not 100% certain what firmware came with the camera. I don't think I updated it after purchasing. It seems like it was definitely 1.0.[something]. It is now loaded with 1.1.4 firmware.
6 REPLIES 6
rs-eos
Which 5D do you have? Original? Mark II, III, IV?
Ricky
FloridaDrafter
Hello, TallMisterHall, and welcome to the forum!
Which EOS 5D do you have? EOS 5DS and EOS 5DS R?
BTW, I went to school with a guy named Paul Hall and he was tall, so his nickname was Tall Paul Hall 🙂
Newton
My typo -- Eos 5Ds.I will edit the OP.
In my haste, I guess I omitted that originally. It's a 5Ds.
Thank you for the reply. For those that don't know, only three cameras can use the W-E1. I have the card, but used it in my 7D mark II.
Your situation is indeed a puzzle, but hopefully, we can figure it out. There may be a bent pin or some debris in the slot, so shine a light in there and see what you think.
Newton
I started noticing, whether it was the adapter or regular sd card, the spring action isn't like it was... I do have some experience with electronics. I wonder if it's worthwhile to open the unit up and look around.
