08-23-2018
04:34 AM
08:36 AM
I have a Canon EOS 4000D. While I was playing my recorded video, there is no sound? Is there a setting on the camera to increase the volume playback? Thanks!!!
08-24-2018 06:05 AM - edited 08-24-2018 06:12 AM
I have downloaded and referenced the Canon 4000D manual, according to which, if the camera is being used to playback movies, it has to be connected to a computer or a TV screen via the HDMI socket to do so. I enclose this page from the Canon 4000D manual.
And... Regarding controlling volume with the camera
08-23-2018 09:22 AM
This seems to happen to some foks. Does the sound play when you view it on the PC or phone?
08-23-2018 03:34 PM - edited 08-23-2018 04:29 PM
Your post did not really specify where you were attempting to play the video back from, but from your comment about a sound volume om-camera device I assume you are attempting to view the video from the camera. If you read the manual:
On P214 it states "The camera does not have an audio/video OUT terminal. Therefore, the camera cannot be connected to a TV set with an analog AV cable."
AND
On P216 it states "Check the sound recording on a TV or computer. The camera is not equipped with a speaker"
So you have a couple of choices:
1. remove the card and put it into a computer or compatible TV
2. connect the camera to a computer or TV via the HDMI port and a cable - sold separately.
I hope this clarifies the situation for you.
08-24-2018 05:04 AM - edited 06-23-2023 07:34 AM
Check your manual. There is no playback speaker on your camera.
08-24-2018 09:17 AM - edited 09-15-2018 01:59 AM
Good catch.... I guess the 4000D is the first Canon DSLR not to have a speaker. Even entry level cameras like the T6/1300D and T7/2000D have speakers.
08-24-2018 07:09 PM
@MikeSowsun wrote:“The camera is not equipped with a speaker”.
Good catch.... I guess the 4000D is the first Canon DSLR not to have a speaker. Even entry level cameras like the T6/1300D and T72000D have speakers.
Hmm. I wonder how it manages to “beep” when it gets a focus lock. =8^D
03-16-2019 06:09 PM
I have a Vixia HF R82. The playback sound was working well, until I plugged a headphone in the AV OUT port and took it out again. Now, the auto level indicator always displays and there is no sound on playback. Any ideas?
03-16-2019 07:09 PM
Check your AV output setting and make sure AV/Headphones setting is put to AV also verify your levels setting either in Automatic or Manual, if in Manual then you have to adjust the levels yourself.
03-16-2019 08:41 PM
Start a new thread down in the camcorder section.
