11-08-2024
01:03 AM
08:11 AM
I have been facing an issue with EoS1500D camera. Below mentioned the test setup and issue.
Setup: I am using a dummy battery (ACK-E10) in the battery slot of an EOS 1500D camera to keep the camera (and display) continuously ON. I have disabled the auto power-off feature in the settings, but after 30 minutes, the camera still goes into auto power-off mode and the display turns off. I tried turning off and then on the ACK-E10 power adapter, but the camera's display did not turn back on. Could you please assist in ensuring the display stays on, even after cycling the power?
11-09-2024 04:35 AM
This behaviour is by design and it is mentioned in the manual on page 185 where it says:-
Even when [Disable] is set, if the camera is not used for 30 minutes the LCD monitor will turn off automatically. To turn on the LCD monitor again, press the <DISP> button.
