02-17-2023
04:05 AM
10:52 AM
Hi i have noticed that my laptop doesent detect my camera with the external Power supply (bought on Amazon), but only if i plug in the battery.
I really Need to use external Power because the camera Is attached into the telescope for 3-4 h.
Whats could be the problema?
02-17-2023 09:39 AM
Are you also connected to the USB port on the camera?
Sounds like there is an issue with your power adapter. If communication has stopped, then that is usually a red flag for ground loop associated with the power adapter not being properly grounded internally.
I recommend that you use the Canon power adapter, which is known to work properly.
02-17-2023 10:52 AM
Yes i am also plugged via USB cable.
When i use my adapter laptop detect a "unrecognize device" error.
