EF-s 55-250 is lens
dadams96
Is the Vivitar hd 2.5x telephoto lens compatible with the canon lens. I can't get focus (af or mf) if the canon lens is zoomed beyond 130mm.
6 ACCEPTED SOLUTIONS
MikeSowsun
No, it is not compatible.
That Vivitar lens is really designed to be used with shorter lenses to give you a telephoto view. If you add it to a telephoto lens like your 55-250 and then zoom to 250mm, you will poor results, or no results at all.
Mike Sowsun
dadams96
that's what I suspected....thanks for the reply
ebiggs1
You do realize those are designed for camcorders?
EOS 1DX and many lenses.
I purchased a bundle that included the Canon Eos rebel t31, an 18-55mm efs lens, an efs 55-250 zoom and the vivitar hd 2.5x58mm telephoto and the vivitar hd .43x58mm wide angle.  The issue is focusing the 55-250 when zoomed out beyond about 130mm. Vivitar has been less than helpful, they want me to return the lens for replacement. However, I am hearing that using a telephoto add-on with a zoom lens that long just does not work. This camera does take video but I do not see how that would make any difference with the zoom lens.
Thanks for the reply.
Some stores will build "bundles" with non-standard products which are very low cost to them in order to create the perception to the conumser that they are getting more for their money.  Unfortunately much of what they throw in are the lowest cost items they can find -- usually "junk" grade -- and these are things you would probably pass over for something better if you were picking them out yourself.
Essentially the thing is like a diopter, but they call it a "lens" -- that way they can tell you that you're getting three "lenses" with the camera.. when really you're getting two lenses and a diopter.
Diopters are fairly specific to focal lengths.  Canon, for example, makes "close-up" diopters (these allow for close working distances)  called the 250D and 500D -- but they are specific as to the range of focal lengths at which these work.  This is because it's not really possible (or practical) to try to make one that universally works with all focal lengths.
Diopters are mostly used for cameras that do not have removeable lenses -- because you're stuck with whatever lens is built-in.  With a DSLR, you can swap lenses -- so ideally you'd just get the lens with the appropriate focal length that you need rather than use a diopter -- and the results are much better.
Tim Campbell
5D III, 5D IV, 60Da
Thank you all, again for your help.
6 REPLIES 6
MikeSowsun
Mike Sowsun
dadams96
ebiggs1
Tim Campbell
5D III, 5D IV, 60Da
