07-06-2017 06:12 PM
Good Day All,
This may sound like a wee bit of a silly question,,, but here goes.
I have a Canon EOS T5I with a EF-S 18-135 (kit) lens.
I have been thinking of upgrading to a Canon EOS 6D.
My question, is there any way I can get the EF-S 18-135 lens to work on the EOS 6D?
Or is there another full frame Canon that I could get?
Thanks All
Chomp
07-06-2017 07:26 PM
The entire series of EF-S lenses & the 3rd party versions are all designed for a smaller sensor than a full frame body uses. This prevents them from covering the full sensor with light at some part of their range. At one end of a zooms range you will get a circular image (like shooting through a pipe) but at the other end you will get a decent image. The Canon EF-S lenses also have been built so that in most cases they will not mount to a full frame body.
07-06-2017 07:26 PM
07-06-2017 07:34 PM
Thanks cicopo.... Not the answer I was looking for, but....such is life. May I will just keep the T5I as a backup.
Thanks again
Chomp
