09-09-2023 09:36 PM
Hi - I'm not super lingo-versed, so I apologize if this doesn't make sense. I purchased a refurbished EF-S 55-250mm for my Rebel XS (she's an oldie). I'm noticing that I cannot focus the lens unless I'm zoomed in/the lens is extended. Is that correct? I was looking for tips online and saw a mention about updating my driver, but it's no longer available on the Canon site. So clearly, I'm at a loss. I really appreciate any help you can provide.
09-10-2023 01:13 PM
The Rebel XS had a weird firmware bug, and it looked like it wasn't focusing the dot in the viewfinder would light up green but it wouldn't take a picture. If it's doing that, and you're not on Firmware 1.0.7 or higher, it could be that bug. Canon Japan seems to have removed access to the firmware, so if that's not the version the camera is on, and it's doing that, it may be time to upgrade.
09-09-2023 10:09 PM
I would send it back for repair or replacement. It should focus at all zoom levels.
09-10-2023 01:36 AM
"I purchased a refurbished EF-S 55-250mm"
Where was this lens purchased from?
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It
09-10-2023 01:01 PM
From Canon's refurbished site!
09-10-2023 01:06 PM
Can you tell us more about your shooting environment? What are you trying to take photos of? Are you inside or outside? How is the lighting? What does your camera display when you *can't* take a photo?
And lastly - which version of the firmware does your XS have?
09-10-2023 01:08 PM
What are you trying to focus on? It amost sounds like it could too close to the lens and/or not enough light for the AF system to focus. Test the lens outdoor on a sunny day.
Look at the front of the lens. You should see a distance printed or stamped on it. That distance is the MFD, Minimum Focus Distance. It only holds true at the shortest zoom focal length. As you increase the focal length the MFD will increase by some amount manufacturers do not always specify.
09-10-2023 01:11 PM
One last thing. Check the setting of the AF/MF switch on the lens. The Canon Online Refurbished Store has an excellent reputation for selling high quality, fully tested gear.
09-10-2023 01:13 PM
09-13-2023 10:31 PM
Thanks! I missed your earlier reply, so to respond to everything:
What are you trying to take photos of? Are you inside or out?
09-13-2023 10:37 PM
Sounds like the lens needs to be returned for repair or replacement. I am assuming that other lens work correctly on your camera.
