01-05-2015 07:29 PM
How do I display the brightness and RGB histograms on the LCD display at the same time during playback on the 7D MII. Page 358 of the PDF user manual shows a graphic of the two together under Lens/Histogram information,but I have only been able to display one or the other, not both.
01-06-2015 02:26 AM
I found the answer. It takes a combination of the Info button and the Multi-controller button to display both histograms. In play back mode press the info button until the image and the histogram selected in the Play3 menu appear side-by-side, then use the multi-controller button(up/dn) to cycle to the other histogram.
01-05-2015 07:53 PM
On 1D Mark IV it happens by cycling the Info button. Try that.
01-05-2015 08:30 PM
Thanks for the reply John.
I have tried that option already and it only displays on e of the histograms. There is a menu option in the Play3 menu called Histogram disp(I assume display) it provides 2 options: Brightness or RGB. There is not option for both, however the same histogram option is available in my 7D and it does display both histograms when i cycle through the Info button. Maybe there is a custom function that affects that I have not noticed that controls or trumps the menu function. I will search through CF to see what I can find.
01-06-2015 02:26 AM
