DSLR BUYING GUIDE
fhashby
I AM NEW TO THE DSLR WORD BUT AM WANTING TO PURCHASE AN UPPER END MID-RANGE DSLR FIR USE DURING MY HUNTING/FISHING EXCURSIONS WHICH AT TIMES MAY BE FRIGID, COLD, RAINY OR ALL OF THE ABOVE.  CAN ANYONE RECOMMEND A CANON MODEL TO FIT THE BILL?
2 ACCEPTED SOLUTIONS
ScottyP
Yeah, no doubt, based on what you said you need.  7d Mk. 2.
Consider going body-only instead of buying a package deal with a kit lens if you can afford to get a good "L" lens, as most of them are weatherproofed, and It makes sense to keep the whole setup weatherproofed.
Scott
A nice feature of the 7D Mk II is its ability to use just about any 'alphabet" lens out there.  It will not use one of the few and unlikely yo encounter EF-M lenses.
The letters are usually a naming scheme that the advertising department came up with.  You really need to set a goal or a requirement standard before you go lens shopping.  Other words, what do you want to take pictures of? Under what conditions?
A couple things to keep in mind, one is, weather-proof is a somewhat misleading term.  Neither the 7D2 nor the lens is water-proof !  Splash proof is a better term. Secondly DSLR's like the 7D2, do need some consideration when you are in colder weather.  Maybe 30 degrees and below.  Batteries don't last nearly as long.
My suggestion as a pretty good starting point is the 7D Mk II and the Canon EF-S 17-55mm f/2.8 IS USM Lens.  This lens is not a whole lot better than the standard kit lens but it offers a fixed f2.8 aperture which is a big plus. No EF-S lens is really weather-proof but this one has some attempts at it.  Never-the-less this would be a great starter combo.
11 REPLIES 11
TTMartin
ScottyP
Scott
And check the refurb cameras in the Canon eStore.
R6 Mark II, M200, Many lenses, Pixma PRO-100, Pixma TR8620a, Lr Classic
Thanks for the assistance and yes my old fat fingers have been broken a time or too
Scott,
Good morning and thanks you for the assistance.  I am assuming the setup you described might be for your system or ?  As you might imagine I will also need some major assistance in selecting a couple of lenses for my "package"  I did take note of your recommended "EF...L" series lenses; however in a general sense, is there a guide to ascertaining all the abbreviations EF, STM, EF-S, SIgma, et al.?
Thank you for the note, John.
It does appear one could save quite  few pesos with the refurbished body and/or package.  Any issues with warranty, tech support, etc. when buying refurbished?
Kindest regards,
Frank Ashby
Strawberry Plains, TN
Kindest regards,
Frank Ashby
jrhoffman75
I never have had problems. Canon eStore has 1 year warranty. Same as new.
Holiday
