DPI
dskolberg
So then when a gallery asks for images of my paintings at 300dpi what do I do.
TTMartin
Unless you are using a flatbed scanner large enough to scan the painting at 300 dpi, don't worry about it.
If you are giving them a photo of the work you are limited by the megapixels of the camera. And then the DPI doesn't matter.
8 REPLIES 8
Waddizzle
What post processing software are you using?  You can set a "DPI" value in an image file's metadata.  See Resolution below.
I use Gimp and/or zoner
I am not familiar with either one of those.  Perhaps someone who is can help.  I posted an image of a screenshot from the freeware application PaintDOTNet.
TTMartin
Peter
@Peter wrote:
Image>scale image.
https://youtube.com/watch?v=8S2cnZ2QR70
They are half tone DOTS, not spots. Because, half tone dots were created using an analog process (photographically through an actual physical screen) and existed long before printer dots came into play.
ebiggs1
DPI stands for Dots Per Inch. DPI is often misused. If someone says they want a photo that is 300 dpi what they really mean is they want 300 PPI.
 A digital photo has no PPI (or DPI).   PPI only happens when the photo is printed.
The resolution of a digital photo is in pixels or commonly MP.  To further complicate this most modern software like PS and LR and Gimp use 300 DPI to refer as a high resolution photo.  They all have a menu where this can be set.  It is found in the Printer Settings.
EOS 1DX and many lenses.
kvbarkley
Do the calculation. If the image is 10 x 12, then the image needs to be 3000 x 3600 pixels (the number of inches x the dpi).
If you have really large canvases you might have to take multiple pictures and mrege them for 300 dpi.
Friends and Family
