03-01-2014 07:02 PM
My camera is only a couple of months old. I have taken hundreds of pictures with it and I usually shoot on shutter priority setting. I took my camera to a wildlife park yesterday. It was clear, sunny, warm, no clouds. At least half of the pictures were blurry. I expect a few but that many? And 6 times the camera took black pictures just like I was trying to shoot at night with no flash. The SDHC card is probably a couple of months old. I format it usually after each use. The battery was fully charged. Any ideas? Do you think my camera is getting ready to break? Thank you.
03-01-2014 07:32 PM - edited 03-01-2014 07:32 PM
You need to have enough light and the iso to match if you are going to get properly exposed images. Chance are, your shutter priority was set to 1/500 or 1/1000, as would be appropriate for shooting on a well lit day, outdoors in the open at a ballgame. Take that same setting into shady areas and wooded trails and your camera now needs to open the lens increasingly wide to compensate for the lack of light reaching the sensor. If your lens has a maximum aperature of f3.5 you might be treating it to 1/8th of the light necessary to properly expose the picture. The problem is compounded if you keep the iso manually set on low (below 400).
One the other hand... I might be totally wrong. Just thinking that it probably has nothing to do with the camera. It being new and all.
03-01-2014 08:30 PM
Thanks for the reply. The pictures were not in the shade. What about the lens going bad? Thanks!
03-01-2014 08:47 PM - edited 03-01-2014 08:49 PM
03-01-2014 08:51 PM - edited 03-01-2014 08:54 PM
I had the shutter speed set to 1/500 for all of them. Never had a camera take totally black pictures on a sunny day! I have taken some blurry pictures but never this many. I have been taking lots of pictures for years. I took the camera out today and took some more pictures just around in the country. I was extra careful and conscious about everything. No black ones but everything is blurred. Thanks.
03-01-2014 08:52 PM
It's not that tough to check the lens. Just shoot some more. ![]()
03-01-2014 10:28 PM
03-02-2014 07:36 AM - edited 03-02-2014 07:37 AM
Can you post a few of the bad photos? If not can you tells us what the ISO, aperture and shutter speed was?
03-02-2014 10:03 AM
03-02-2014 10:04 AM
Did you happen to check the pictures on the LCD as you took them? Isn't it surprising you didn't notice a totally black picture until you got home? ![]()
OK, for now, you must set the camera back to factory defaults. Remove all batteries for several hours. Make sure you have good fully charged batteries. Clean the lens contacts and the camera contacts with a small amount of denatured alcohol on a Q-tip.
Set the camera to fully automatic and the lens to AF. Go outside on a bright lite day and try it again.
