01-01-2019 09:32 PM
Hi all,
I was setting up to use my T7i and when turning on the camera I noticed the LCD was a lot dimmer than normal. went into the settings and adjusted it but even at max brightness the appearance was still dimmed. I proceeded onward and took a photo at which point the lcd went all black and never came back on. I was able to take one more photo with the LCD never coming back on. At this point I try to restart the camera but after turning the camera off I was no longer able to get anything on the camera to power on. The sensor doesn't flip, the indicator that there is a memory card is inserted doesn't flash at all and buttons do nothing. I've checked a few other forum posts to try and see if they had a solution but I wasn't able to find anything that worked.
Things I have tried:
Applying pressure to the memory card door in hopes to make whatever contact it needs to be regisered as closed
Charging the battery fully and placing it back in the camera
Leaving the battery out for 15 minutes and then placing it back in.
Swapped out different memory cards
If anyone has any guesses as to what could be wrong, please let me know!
01-01-2019 09:46 PM
What is the temperature of the camera? Is it “cold”, or at or near an average room temperature?
01-01-2019 09:53 PM
08-12-2019 02:46 AM
