08-21-2020 03:04 AM
08-21-2020 09:29 AM
Since you have to ask I am guessing you are not a camera technician? So, your best bet is to call Canon for a service estimate. I'll even supply you with a number. 1 (800) 652-2666 that will get you going.
08-21-2020 12:24 PM
Welcome to the forum Angelg2091
Since the part is bent it might have dameged the conductor to the LCD. I agree - service is required.
You could probably separate out an LCD problem or a sensor problem by taking an image and seeing if it was recorded on the SD card.
08-21-2020 01:26 PM
Or use the HDMI cable and plug the camera into an HDMI tv or monitor.
08-21-2020 04:49 PM
