Canon T6 Rebel & 18-55 Lens will not focus or take pics. Help!
JABrazer
I am not sure if its the lens or camera or both. Its very blurry and will not take pics. I have tried everything I can think of. HELP! The camera is only 2 days old!!!
Take off the macro and try it. That will quickly answer the question. But it sounds right.
21 REPLIES 21
JABrazer
diverhank
Please try this...
Take a look at the lens.  There should be a switch labeled AF/ MF.  Make sure the switch is set to AF.  When the camera won't focus or take pictures, it's usually because the lens is set to MF - manual focus.
Diverhank's photos on Flickr
JABrazer
It is set to aF
jrhoffman75
Did it ever work?  Did anyone play with settings?
Go into menu and clear all camera settings. Then switch to green A+ and try.
JABrazer
It worked on day 1. Then the next day it didn't.
Is there a specific button to clear them because I've looked all through menu
Switch to P mode and look under yellow wrench 4.
JABrazer
Cleared. Didn't fix it. Any other suggestions?
No. If you are close to where you purchased go back for exchange maybe.
You could call Canon at 1-800-OK-CANON.
JABrazer
Do you think it's the lens or the camera?
