05-29-2025 07:08 PM
05-29-2025 08:51 PM - edited 05-29-2025 08:51 PM
AlexAndErika,
If you are going to shoot in Manual, most people recommend you use a shutter speed that is twice as fast as your frame rate to get the most natural looking flow of movement. That is, if you're using 30fps, you'd set a shutter speed of 1/60th of a second. After that, you can tinker with your aperture and ISO to get a good exposure.
Some people feel that 1/60th's of a second let's in too much light, and so they will use a 3 stop neutral density filter to cut down on the light and avoid over exposure.
The audio in your clip had excellent quality.
In my camera ( a T8i ), if I set the Mode to Av, TV, or P, the camera automatically reverts to P Mode, and sets the aperture, shutter speed and ISO for me, and adjusts the exposure on the fly.
If I was shooting a video with changing lighting as you swing from one end of the field to another, I don't think I would use Manual, because you would be constantly tinkering with the settings to get your exposure right.
Steve Thomas
05-30-2025 12:35 AM
Thank you for the feedback. What mode would you recommend shooting in?
I have not spent any time understanding the different modes on the dial.
I have been shooting in 60 fps so I will need to make my shutter speed 1/120
I added an ND filter to the lens. Not because I was thinking of the lighting. I just wanted an extra layer of protection on the lens.
I also use a RODE mic so the audio has been decent.
05-30-2025 11:11 AM
AlexandErika,
You could put your camera in P Mode, where the camera will choose the appropriate shutter speed and aperture, or in Tv Mode, where you can adjust the shutter speed and the camera will choose the appropriate aperture for a proper exposure.
I thought your video was a little dark, so you might want to add a touch of positive exposure compensation, maybe a 1/3 stop.
Manual is ok if you are in a fixed location where the lighting is not going to change, but if the lighting is changing by swinging your camera back and forth, you want to be able to adapt quickly, and a semi-automatic Mode, like Tv or Av or P is probably a better bet.
Steve Thomas
05-30-2025 11:29 AM
Appreciate the feedback. Is there a good resource online to read more about the different modes like Tv, Av, P, etc?
Of the 3 modes you mentioned, what would you likely be shooting in? We are in Southern California, the weather and lighting is always pretty consistent.
05-30-2025 12:55 PM
If I am in consistent lighting, I might use Manual. If I'm going from shadow to sunlight, I might use one of the semi modes like Av or P. I don't shoot moving subjects very often, so I don't use Tv too much.
On my camera, Av reverts to P anyway, so I'll go with that more often than not. If I adjust my exposure compensation up or down a little bit, it adjusts my ISO to make the exposure brighter or darker.
Steve Thomas
05-30-2025 01:46 PM
I would avoid using an ND filter unless you want to use wider apertures. For desired lens protection, use a high quality clear filter. I personally use B+W brand of filters.
As mentioned, shutter speed would be fixed and typically based on frame rate (180º shutter angle rule).
For modes, you could potentially try Shutter Priority (Tv), though I'd be more included with either Program (P) or Manual (M). i.e. you definitely want full control of the shutter speed and potentially the aperture.
If using manual, you could always set the camera to use Auto ISO too just in case clouds roll in/out while shooting.
