10-17-2022 08:51 PM
I recently purchased the Canon R7 and i do own the Rp as well. I am using the rf 100-400mm usm and i have noticed that even on sunny days with sufficient light i do get substantial Noise on the images even processed trough DPP. The noise is pretty visible even on ISO 1250. I have tried both, mechanical and electronic and the mechanical shutter is way worst. Noise reduction for high Iso is set to standard. Im just wondering if i have some settings done wrongly or what is the case. I know APC sensors usually have higher noise but even with my old Rebel t7 i havent had so much noise in the images. Any advice will be appreciated
01-29-2023 06:21 PM
If you are shooting RAW and processing in DPP I suggest you turn off all in-camera lens and noise correction settings. You can do everything in DPP and you will avoid slowing down burst speeds in camera because it won't have to be doing any processing.
12-29-2023 08:45 AM
Hi!
did you manage to solve the noise issue? Cuold you sare with me how did you solve it? I’m having the same problem.
