Canon R3 extreme banding in available light extreme iso ;extreme speed; stopped down aperture f22>
Matjulu67
Hello friends
Pro wildlife  safari in Southern Africa .
Equipment:   2 R3s   &  R5 mk2
Lenses   Rf400mm 2.8  RF600mm  Rf70-200 2.8 Z
Experiencing shocking purple banding in available light  subjects animals burds all sorts.
dragonflies in flight extreme settings  to test for suspected problems with 1 R3 body..
Settings
Speed 1/64000  ISO 102800
Aperture stopped right down south of F22
Why the test to expose / accentuate aggravate expose the problem!!!! ?
only one R3 does it
Both configured identical.
Suspect Problem
15 REPLIES 15
I pointed out they werent RAW..
Not bothering yo raw file server them..you can see the prob clear as
Cheers
Correct..i told all they weren't.
Thyre screenshots of the RAWS.
Ehats your Problem. You can see the mess!!!!
That's fine if you cannot provide links to access the original RAW files.  However, additional help from those on this forum will be limited.
Ricky
Pathetically Pedantic Procedural Politik
Ive been round shooting for 50 years and on principle if these screenshots dont illustrate the problem  forget it
kvbarkley
In order to narrow down exactly where the problem is we need to start with one thing at a time, hence asking for raws to check the sensor and digic.
With what you showed it could be an LCD problem.
Thank you kindly,  I apologise for my terse reply earlier this whole trips going pear shaped.
I will send you a link to the raw file tomorrow
I would say its not the LCD as you can see it very clearly on the electronic screen.
Good night
