07-11-2020 04:45 PM
07-11-2020 05:20 PM
Sounds like either the adapter or the lens could be bad. Try the adapter without the lens.
Also, the camera may be trying to write to the memory card. Or, it could be trying to retract the lens when you turn off the camera, which is a setting that you should be able to disable if you want.
07-11-2020 05:29 PM
07-11-2020 06:20 PM
@d_tol wrote:
Thanks for your reply.
The lens is an older loaner and is not in tip-top shape. I suspect it might have to do with the shutter not being told to reset at shut-down.
I've just followed your advise and am almost sure it's the lens that is failing to communicate with the camera at shut-down.
It's not unworkable but is an inconvenience as it leaves me with 2 working options: either keep the camera on when looking for a shot, or patiently wait until it decides it wants to switch on.
Read your instruction manual. I am almost certain that because of the lens shutdown when the camera is shut off, that you need to turn off the camera whenever you change lenses!
10-23-2020 11:43 AM
Hello everybody!
I too have experience this problem. I just bought an M6 mark 1, and I use only two lenses. Keep in mind I do use a EF-M to EF mount. I have a Tamron 10-24mm (the older one with no stabilization), and a sigma 24-105mm art lens (this has image stabilization). When I have the tamron lens, the m6 powers on and off just like that - no problems. I can not say the same for my sigma lens AT LEAST when I have image stabilization on. When I turn that setting off on the lens, then my camera continues to turn off and on just fine.
TLDR: I have the same problem powering down and turning on, when I have image stabilization on my lens with the converter.
10-23-2020 06:00 PM
@jushjoshjosh wrote:Hello everybody!
You have a lens problem. Nothing of the sort happens with Canon EF lenses. You might want to play with the setting that controls retracting lenses on power down and power up. But, first and foremost, you have a third party lens problem, not a Canon camera problem.
06-17-2024 12:18 AM
thanks for your experience sharing! i have m5 and sigma ef 18-200.they have same problem. it always cannot turn off completely even freeze up.i saw you comment and i try to turn lens stablilization off, it works !!! thank you again.english is not my native language,sorry.
