Canon M50 Stuck Shutter?
chkrd
Well, my M50 seemed to have given up. My shutter is closed, even when the camera is powered off. When I switch it on, the screen and viewfinder don’t turn on, and there’s a faint pulsing sound like the motor is trying to activate the shutter.
I’m trying to sort out if this is a full shutter failure, or just the motor? I’d love to repair it and get the camera back up and running if at all possible. Any help is appreciated.
5 REPLIES 5
Mark35mmF2
Hi there,
It would be hard to say for sure exactly where the failure lies until the camera is opened up by a repair technician, however one thing I would suggest is to make certain that the camera itself is causing the issue. Testing with a second battery is always a good idea, and I definitely recommend checking the camera either with a different lens mounted on it or with no lens at all, just to make sure the lens is not the cause of the issue.
Otherwise, you can generally get some better idea of the issue after receiving a repair summary, that would indicate what parts were replaced and what adjustments were made to resolve the issue.
Canon Support | Service & Repair | Canon U.S.A., Inc.
ajagana
I have the exact same issue. Did you find a solution to this? Thanks.
Unfortunately no, the price to repair it outweighed the value of my M50. Ended up upgrading to another camera, which now has a stuck shutter as well.
Maud65
Hi CHKRD
Did you ever get a response to your canon m50 problem, I have the same issue and also have had no response like yourself I just need to be able to use again
Welcome to the Canon Community!
The Community isn't intended for immediate assistance. If your question is urgent, contact support directly by calling 1-800-OK-CANON (800-652-2666). They are available weekdays from 9am to 6pm (ET).
If you're outside the USA, please click HERE for support options.
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
