12-14-2016 03:15 PM
What model of Rebel has the fastest autofocus set in auto mode, indoor photography.
12-17-2016 03:26 PM
Fastest auto focus should go the same as fastest stabilizer without zooming the object.
Suggest a lens that best describe of what I am looking for.
12-17-2016 04:19 PM
@newsense52 wrote:Not all expensive lens have great performance.
For indoor stage shooting with moving persons with less lighting.
Not all expensive lenses have great performance in all ways that can be measured. But, most all expensive lenses will outperform inexpensive lenses in most ways that can be measured.
If you're referring to shooting video under low light conditions, then a Rebel camera body will definitely be a factor in the quality of the video that you capture, if not THE limiting factor.
Rebel camera bodies are not known for their low light performance for shooting stills. Because of that fact, Rebels are not known for excelling at capturing video under low light conditions, either.
Rebel bodies are not kinown for their AF performance, either. The single most limiting factor in AF performance in Rebel camera bodies are the number and type of AF points. Rebel bodies are good for new DSLR users. They are not for the demanding camera enthusiast, although the T6s comes close.
Rebels are not known for the performance of their built-in flash units, either. The built-in flash will not be very useful shooting subjects much more than 10 feet [ about 3 meters] away.
As far as a lens suggestion to capture images on a poorly lit stage, I'd suggest that you look for a lens that has a wide aperture, first and foremost. If you want to avoid 'zooming the object", then I would next suggest that you look for a focal length of less than 35mm.
Finally, if you want a wide aperture, a short focal length, AND inexpensive, then you're going to have to sacrifice having Image Stabilization, as well as, Auto Focus. Canon does not make such a lens. A good example of such a lens would be a Rokinon 14mm T3.1 lens. Rokinon also makes a lens for APS-C bodies only, the 16mm T2.2 lens. Either lens can be focused to what is known as the "hyperfocal distance", which will cause everything beyond a few feet to be in focus, eliminating the need to adjust focus, at all.
