Canon EOS Rebel T5. Not taking photos/EXSIM
LandoElliott
I have not been able to take photos on my camera for a while now, one day it just stopping taking photos. I go to click the shutter and it wont take a photo and on the chance it does its no clear. I have no idea how to fix this or what is causing it. Please help!
9 REPLIES 9
kvbarkley
VIP
VIP
Have you tried to reset the camera to its defaults? Sounds like a focus issue. What lens?
LandoElliott
I am not sure how to do that but also the defeat lens im not 100% what one it id tho
I went to reset my camera and I do not have a 3rd page in my setting I only have the first two.
You need to get out of the fully automatic modes and switch to PAS or M to see this menu item. See the little star in the manual excerpt I linked? That is what that means.
LandoElliott
Thank you so much! I will try this when I get home tonight!
stevet1
Whiz
Whiz
Are you sure you have a card in the card slot?
The default setting on my camera allows a shutter release without a card, and I have to go into the menu and disable that in order to prevent that from happening.
Steve Thomas
Tronhard
Hi Lando or Elliott?
Does any message appear on the screen when you attempt to take a photo?
What lens are you using when you go to shoot?  If you have more than one lens does this happen with all of them?
cheers, TREVOR
"The Amount of Misery expands to fill the space available"
I have a canon 28-80mm lens and a efs 18-55mm lens. How ever i don't offend switch them as I dont know the different between them. I got the 28-80mm with the first camera body I had and then the other came with the newest body I own. I believe I did switch them out at one point and yes they are doing the same thing with both lens.
Avatar
