10-21-2016 10:19 AM
Hello,
I use the Canon EOS Image Transfer Utility to import photo's from my Canon EOS M3 to my PC.
Two questions:
Thanks in advance,
S.J. Westra
10-21-2016 10:39 AM
You can do whatever you want, if you use Lightroom. Not so much with EOS Utility but maybe there is. I don't know.
10-21-2016 11:05 AM
Thanks!
Does Lightroom also support transfer over wifi?
Thanks,
S.J. Westra
10-21-2016 11:21 AM
No, not without extra gadgets. You can do this with an EyeFi card or really any system that lets you automatically send photos wirelessly to your computer.
LR also has tethered, realtime, shooting but it requires a cable. It is almost done instantly. Canon's software is the basic program to get you going with your camera. There are better commercial programs like LR that do more.
10-21-2016 01:27 PM
Yes you can!!!
Just click on the Destination Folder... button to change the formatting of the folder name
10-21-2016 01:36 PM
@sjwestra wrote:Thanks!
Thanks,
S.J. Westra
Yes, since your EOS M3 has built in WiFi yes you can transfer files to Lightroom via WiFi, but, you end up going through EOS Utilities to do it. So there is no advantage to using Lightroom for that function. But, if you want to use Lightroom, yes that is a capability. Note: Transferring RAW files via WiFi can be slow!!!
10-21-2016 02:01 PM
Hi TTMartin,
I think you showed an image of the EOS Utility. For that one a USB cable is required if you have an EOS M3.
I meant the Image Transfer Utility that can be used for wireless transfer in combination with the EOS M3, that's a different tool.
Both tools run on my PC...
In short: I would like to transfer the images wireless and I would like to define the folder name convention (- instead of /).
Best regards,
SJW
10-21-2016 02:14 PM
@sjwestra wrote:Hi TTMartin,
Best regards,
SJW
Nope you can use EOS Utilities over WiFi too.
Instructions below are for the 70D, your EOS M3 will be similar.
Sending images to a computer (Wi-Fi function) (EOS 70D)
11-06-2016 11:13 AM
I was able to use the Image Transfer Utility to upload over wifi.
However, I was not able to change the folder naming convention.
Leave it as it is for now.
Best regards,
SJW
