Canon EOS 7D Battery Problem
Dexter33
Eversince I purchased my camera, I have to take my battery out everytime I have finished using it, otherwise my fully charged battery drains out, completely. I do notice when I leave my battery in my camera, the top LCD always shows GPS and LOG and I don't know whether this is causing battery drainage?
I do not use back LCD display to view what I am shooting, only the odd time to view a captured image. I very rarely use flash also and my battery is fully charged and at maximum, only lasts one day. I have a couple of spare batteries and this issue happens on with them all.
9 REPLIES 9
The 7D doesn't have built in GPS.  GPS is supported via an optional accessory.  Can you confirm the model of your body and if you have this accessory?
If your device or optional accessory has a "mode2" option, thats the one you want.  It turns GPS off when the camera is turned off.
In "mode1" GPS remains on and periodically checks for Geo location even when the camera is off = drains battery.
ebiggs1
"The 7D doesn't have built in GPS."
I had two 7D's and neither drained the battery faster than the average camera. In fact the 7D is pretty conservative with battery power.
EOS 1DX and many lenses.
Dexter33
It is Mark II model and on specification list, it does indeed show it has GPS. I have WiFi SD Card as an additional extra.
I will indeed try mode2, thank you.
" I have WiFi SD Card as an additional extra."
Whether this has anything to do with faster battery drain or not, you need to ditch it.  They are poor at best.
If you are not using the Wi-Fi, you should put the camera in USB mode.  However, it is best to not use the Wi-Fi card because it is pretty slow when it comes to data transfers.
Thanks for confirming the model "MKII"
Mode2 should resolve the behavior if thats the actual issue.
Dexter33
How would I put it into this mode shadowsports?
Your camera does not have that option.  Turn off the GPS when you are not using the camera.  I keep it turned off most of the time, because most of my shots in a shooting session are in the same general area.
For example, if I am shooting a soccer game, then I do not need the battery drain of the GPS being enabled for the entire game.  I may take a few test shots with the GPS enabled just to capture the location data when I first arrive, and then turn it off.  I can copy the GPS data to the rest of the photos in post.
Again, if you are not using the Wi-Fi, then set the camera to USB mode.  In fact, it would be best to simply remove the Wi-Fi card from the camera.  The Canon supplied card has a number of limitations, which make the card not very useful.
Thank you for your advice.
Friends and Family
