12-11-2013 11:02 AM - edited 12-11-2013 11:02 AM
Canon 7D pop up flash… My pop up flash "Pops Up" but does not fire. Please help!
I am aware of them micro hot sure button sometimes stuck thingking something is attached and will disable the pop up flash form opening. This is not the case no. I pops up when asked but does not fire. Is there a contact that i need to check... Im stuck ..
thank you! M
12-11-2013 07:08 PM - edited 12-11-2013 07:22 PM
I'm grasping at straws but check the user manual, there is an option to turn the pop up flash off...try page 115 - check that and see if somehow yours is set to off by accident.
12-11-2013 02:44 PM
Try it in Av, Tv or Manual mode and not full auto mode and see if it would work. If it does then this is normal. In full auto, the camera decides whether flash is needed, not you or me. If the popup flash still doesn't work, then I think there's a problem.
12-11-2013 04:18 PM
12-11-2013 07:30 PM
