09-25-2018 11:51 AM
I'm using Canon 6D with Pocket Wizard as a remote trigger plugged in to the RF603/C3 port. I was able to preview the pictures I took using the playback button, but now for some reason the playback and display won't turn on until I unplugged the remote cable. I don't think I messed with any of the settings or perhaps I accidently set it the wrong way. Anyone know what's the correct setting to be able to view/playback the picture without unplugging the remote cable. I don't use live view when using the remote trigger.
Thanks.
Emil.
09-26-2018 10:21 PM
@eharsa wrote:Hi,
Thanks.
Emil.
Check that your remote trigger is not holding the shutter half pressed.
09-26-2018 10:21 PM
@eharsa wrote:Hi,
Thanks.
Emil.
10-10-2018 11:38 AM
Waddizzle, genius my man. There is a switch at the trigger cable to make it autofocus or manual focus, it was set to manual so it was preventing it to check the playback. Thanks for the solution, I was browsing around the menu and couldn't find anything.
Regards,
Emil
08-31-2019 11:35 AM
Hey @Waddizzle, how would I check this? I have the same issue, but am using a Vello ShutterBoss II. I can't get any camera functions to work once I connect the unit. Even if it is not powered on. I suspect I have a short somewhere.
08-31-2019 01:36 PM
@DaBrownCO wrote:Hey @Waddizzle, how would I check this? I have the same issue, but am using a Vello ShutterBoss II. I can't get any camera functions to work once I connect the unit. Even if it is not powered on. I suspect I have a short somewhere.
Contact Vello or the vendor who sold it to you. You may have a bad unit.
09-01-2019 03:01 PM
Thanks Waddizzle. That's what I thought. It's a few years old so I guess it's surpassed its lifetime.
