07-23-2021 10:18 PM
Hi Guys,
My canon 6D mark II is experiencing a strange problem: when I used the viewfinder it took a long time to focus, and then it showed 30'' flashing and I can't press the shutter button. I used aperture mode set as 2.8. It seems to be an error with the light meter sensor. When I set auto ISO mode, the ISO increased to 12800 and the shutter time was 4''. I were able to press the shutter button however the photo was over exposure (of course). Please note that I tried it outside under the sun shine.
When I turned it off and on, the problem is still. However, when I removed the battery and put it back, I can take the shot normally with viewfinder for 2 or 3 minutes then the problem is back again!
I have changed many lenses / batteries and still got the same issue. However the camera works normally in live view mode.
My canon 6D II is practically new as it's only 6000 shutter counts.
I am not sure it's hardware or firmware? My firmware is 1.1.1.
Thanks so much for your time.
Cao
07-23-2021 11:53 PM - edited 07-23-2021 11:53 PM
This is likely a problem with the shutter.
Reset your camera settings to defaults. Use a Canon lens. If this occurs with multiple Canon lenses, your camera needs service.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
07-24-2021 12:52 AM
Hi Rich,
Many thanks for your reply.
I've reset it to the factory setting and have tried with many Canon lenses but the problem is still there.
I wonder if it's with the shutter then:
- Live view mode works normally (I can press the shutter)
- I do the trick: remove battery, put it back then it works for few minutes with viewfinder and the problem comes back!
Regards, Cao
07-24-2021 01:55 AM
Hi there,
Since the issue is till there, I would agree there is likely something happening with the shutter or mirror assembly that would need service.
https://www.usa.canon.com/internet/portal/us/home/support/service-repair
