01-07-2014 01:09 PM - edited 01-07-2014 01:33 PM
Hi.
I have both a CF card (sandisk 32Mb extreme 60MB/s) and an SD card (sandisk 32gb extreme pro 95MB/s) inserted and in the menu under the Record func+card section i have the record func. set to Rec. to multiple. My issue is that sometimes my video files are only copied to the SD card and not the CF card although photo files are saved to both.
Any help would be greatly appreciated.
Canon 5D Mkiii 50mm f/1.4. EF 16-35mm f2.8L II USM. EF 24-105mm f/4L IS USM.
EF 24-70mm f/2.8L USM. EF 100mm f/2.8L Macro USM. EF 70-200MM f/2.8 L IS USM
Speedllite 430EX II
01-07-2014 02:51 PM - edited 01-07-2014 03:13 PM
I asked a videographer friend and he said,....
You can select which card movies will be recorded to, but there is no overflow or mirroring capability
for movies with the 5d Mk III.
01-07-2014 03:20 PM
