11-06-2019 06:52 AM
Has anyone tried this combo? I am having a bit of trouble with it. I am trying to get a godox SK400II strobe to fire. The trigger is mounted on the hot show of the camera. What happens is this: The trigger needs to be sync'd with the camera. That is done by pressing the shutter realese halfway. (it also syncs when AE or AF buttons are pushed) Once the sync occurs, the flash fires if I take a picture.. However, it will not fire without the sync. When the camera dioes sync with the trigger, it remains sync'd only a few seconds. So I have to keep sync-ing it , before I can take a shot and have the flash fire. Is there some way that the camera will remained sync'd for a longer time? Thanks in advance
11-06-2019 04:13 PM
That seems to be what's happening.
So I just set the AE button to " AE hold."
That seemed to do the trick. The trigger stayed sync'd for a long time, even after taking a shot
Pressing the AE button once more un-sync'd it.
Great Idea!
Thanks
11-06-2019 09:39 AM
What did Godox say?
11-06-2019 09:46 AM
haven't tried them yet. That's the next step. Tx
11-06-2019 01:55 PM
@Gino-Mazzaferro wrote:Has anyone tried this combo? I am having a bit of trouble with it. I am trying to get a godox SK400II strobe to fire. The trigger is mounted on the hot show of the camera. What happens is this: The trigger needs to be sync'd with the camera. That is done by pressing the shutter realese halfway. (it also syncs when AE or AF buttons are pushed) Once the sync occurs, the flash fires if I take a picture.. However, it will not fire without the sync. When the camera dioes sync with the trigger, it remains sync'd only a few seconds. So I have to keep sync-ing it , before I can take a shot and have the flash fire. Is there some way that the camera will remained sync'd for a longer time? Thanks in advance
It almost sounds like it stays synched for as long as the metering is active.
11-06-2019 04:13 PM
Great Idea!
Thanks
