01-20-2014 01:39 PM
Hello,
I've noticed that my Canon 5D Mark III underexposes somewhere between 2/3 stops and one stop.
I've taken a test photo and I've attached the histogram and the exif. I photographed a white sheet of paper
Is this behaviour normal or is there a problem in the camera's metering system?
Thanks,
Catalin
Histogram
Test photo
I have also attached the full exif:
[Image]
Make = Canon
Model = Canon EOS 5D Mark III
Orientation = top/left
X Resolution = 72
Y Resolution = 72
Resolution Unit = inch
Date Time = 2014-01-20 21:16:29
Artist = Catalin Fuioaga
YCbCr Positioning = co-sited
Copyright = Catalin Fuioaga
Exif IFD Pointer = Offset: 360
GPS Info IFD Pointer = Offset: 9554
[Camera]
Exposure Time = 1/200"
F Number = F5.6
Exposure Program = Normal program
ISO Speed Ratings = 2000
8830 = 2
8832 = 2000
Exif Version = 30, 32, 33, 30
Date Time Original = 2014-01-20 21:16:29
Date Time Digitized = 2014-01-20 21:16:29
Components Configuration = YCbcr
Shutter Speed Value = 7.63 TV
Aperture Value = 5 AV
Exposure Bias Value = ±0EV
Metering Mode = Partial
Flash = Flash did not fire, compulsory flash mode
Focal Length = 105mm
Maker Note = 8152 Byte
User Comment =
Subsec Time =
Subsec Time Original =
Subsec Time Digitized =
Flashpix Version = Version 1.0
Color Space = sRGB
Exif Image Width = 2880
Exif Image Height = 1920
Interoperability IFD Pointer = Offset: 9326
Focal Plane X Resolution = 1971.253
Focal Plane Y Resolution = 1975.309
Focal Plane Resolution Unit = inch
Custom Rendered = Normal process
Exposure Mode = Auto exposure
White Balance = Manual white balance
Scene Capture Type = Normal
A430 =
A431 = 073024017512
A432 = 24/1, 105/1, 0/1, 0/1
A434 = EF24-105mm f/4L IS USM
A435 = 00001bcf3a
[GPS]
GPS Version ID = 2, 3, 0, 0
[Interoperability]
Interoperability Index = ExifR98
Interoperability Version = Version 1.0
[Thumbnail Info]
Compression = JPEG Compressed (Thumbnail)
X Resolution = 72
Y Resolution = 72
JPEG Interchange Format = Offset: 11444
JPEG Interchange Format Length = Length: 3320
[Thumbnail]
Thumbnail = 160 x 120
01-14-2015 07:51 AM
Somehow, my EOS 5D Mark III got into a mode where it was creating very dark images. I was using normal camera automatic settings (at least I did nothing to change any settings). The "Clear All Camera Settings" did the trick for me as stated by @marcosphoto. Now they look normal again.
01-14-2015 10:49 AM
Hey thats good news and interesting too - now you've proven that the info I came across actually does something. I have run into a period where I have used my camera very little, so I've had little need to run any controlled testing on mine yet. I did a wedding a couple months ago and it was behaving.
