08-12-2017 05:12 AM
Hello all !!
New 1Dx mk I owner here.
Can I see the focus point(s) on captures I've just taken on the back screen?
Respectfully,
Acquired Focus
08-12-2017 07:32 AM - edited 08-12-2017 07:37 AM
@AcquiredFocus wrote:Hello all !!
Respectfully,
Acquired Focus
You should. I can see it with my 6D, and my 1D Mark IV. Check the menus or the user manual.
[EDIT]. Just be aware that you might only see an AF point ONLY if it is active and locked. In One Shot mode, this is typically the case. In AI Servo mode, depending upon your settings, the camera may still take a picture without having an AF lock. Basically, if you can see the AF point in the DPP application, then you should be able to see it in the camera.
Respectfully,
Acquired Focus
08-12-2017 10:02 AM
08-17-2017 05:51 PM
I don't know about the 1Dx, but on my T6S, the focus points won't display if the lens distortion correction is on. I guess it is because the correction destroys the 1:1 relationship of pixels on the screen.
