Canon 1DX Mk II Problems: How to kill the battery in one easy step.
JohnTh
Have your 1DX2. Just pull out any card(s) you have in camera. Just leave the camera in Auto-Off mode (do NOT turn it off from the on/off switch).
Check again in few (two?) days.
Expected:
Battery = alive.
Actual:
Battery = dead
(...or heavily drained out)
IIRC also 5D3 has/had this problem...
I think that a firmware update can fix/enhance this thing.
TIA for the fix 🙂
my 2c & HTH,
John Th.
4 REPLIES 4
Waddizzle
Disable the internal GPS when not using the camera.  Problem solved.
GPS is always disabled. Problem is NOT solved. 🙂
my 2c & HTH,
John Th.
In that case, I suggest that you turn the camera fully OFF.  Standby mode consumes power, too.
jrhoffman75
Seems like a bug. Call Canon at 1-800-OK-CANON.
