07-06-2016 02:58 AM
Have your 1DX2. Just pull out any card(s) you have in camera. Just leave the camera in Auto-Off mode (do NOT turn it off from the on/off switch).
Check again in few (two?) days.
Expected:
Battery = alive.
Actual:
Battery = dead
(...or heavily drained out)
IIRC also 5D3 has/had this problem...
I think that a firmware update can fix/enhance this thing.
TIA for the fix 🙂
07-06-2016 08:13 AM - edited 07-06-2016 08:13 AM
Disable the internal GPS when not using the camera. Problem solved.
07-06-2016 12:35 PM
GPS is always disabled. Problem is NOT solved. 🙂
07-06-2016 01:09 PM
@JohnTh wrote:GPS is always disabled. Problem is NOT solved. 🙂
In that case, I suggest that you turn the camera fully OFF. Standby mode consumes power, too.
07-06-2016 01:51 PM
