02-08-2013 04:48 AM
Dear Friends,
I am a proud owner of 7D for the past 2.5 yrs and have done many trips and shooting with that.
I am not using any battery grip. Have 2 Canon original battery with me.
Fromyesterday night I am getting an error "Cannot communicate with battery". It is same described in the below link also :-
I am using Original Canon battery and I have tried with both of them but no result.
As per User Guide ,
If the message "Cannot communicate with battery" is displayed when checking the battery status, select [OK] and continue shooting. Please note that the battery level indicator will appear blank.
My concern is :-
1. If I ignore that and continue shooting , will it create any problem to the Camera functionality ?
2. Wil the battery drain fast due to that ?
I am Ok with not displaying the battery infor as of now ( which I will repair by Canon) but need to confirm that the battery functionality will remain as usual. I will be travelling for a birding trip soon and I due to short time I dont want to send it to repair...
Please guide.
Warm Regards,
Ari...
11-24-2013 04:20 PM
Hello friends, I sent minha7D for Canon to Brazil.
she remained for several days in tests. and showed no defect.
the defective battery not reconheser, avia disappeared.
The technical report was the following ..
a problem in the battery, (Original) caused this error ..
However, by staying a few days off, this information is lost in the memory of the 7D ... and everything started to work normally.
Only then I'll have to buy another battery.
11-24-2013 04:27 PM
According to the technicians from Canon. this error is caused by the battery.
desapareser for the error, you should leave the mamera off without batteries for a few days, al this information is lost. and everything returns to normal.
however you should change the battery, because it must be bad.
Sorry for the google translation
12-07-2013 04:57 PM
Ok, so 2 1/2 weeks and $302 dollars later, I just picked up my 7D. No errors, thankfully. Cleaned sensors - thank you.
90 day warrantee on this, so if the issue arrises again before March 7th- and I hope not - then it's covered.
However, can someone here from Canon translate this. - picture attached.
Very vague "Adjustments made to circuit board" What kind of adjustments, was it replaced, should I expect to have this "adjusted" again lets say a year from now? Did the batteries and / or updated firmware cause the board to go haywire? I take immaculate care of the camera so this was a totally out of the blue error when this started.
Is that the leading cause of this "battery communicate error?" After shelling out this kind of money, I thought I would get a more detailed explanation. Although I appreciate the fix, I see this error with MANY 7D cameras all over the web and other forums. Just Google "Cannot communicate with battery 7D"
If this is a flaw, Canon needs to own up to this and issue a recall if these circuit boards are an issue.
(Clean and adjust to factory specs - That I understand was sensor cleaning and a deep check to see if the camera is working perfect)
12-19-2013 09:00 PM
Hate to beat a dead horse with this issue, I did have to drop close to ANOTHER $200 on two new EP-L6 batteries. I went to use the camera a few mornings ago - first time in 4 days on fully charged batteries, noticed the battery icon - using my battery grip with 2 L6's - showing 1 bar...15 minutes later camera went off, batteries died.
Anyway long story shot, I looked at the Battery info on the Menu screen, both battery's showed 1 red bar on the Battery perfromance"...meaning - "Battery has reached the end of its useful life, and should be discarded and replaced with a new LP-E6 battery pack."
Before the "cannot communicate" problem, I had 3 green bars on my battery performance.
So to Mike at Canon that posted back in February, YES this affects the battery.
12-20-2013 12:03 PM
"I am not certain this is a "camera" issue.
Well, of course it IS a camera issue because it shows up on the camera but I don't think it is the camera causing it. I have seen this on several different models. I am sorry I don't know exactly what works to correct it except new batteries."
I am going to repeat my post from long ago. This is only my 40 years of experience with Canon equipment. I am not a technician but this is what I have known. Possibly there is a large batch of faulty batteries out there (even Canon).
I discourage the use of 3rd party batteries ever. Strongly discourage it. ![]()
Now I am sure there is that specific camera that has a flaw but I still will go with bad batteries.
12-22-2013 11:24 AM
Hi Mike,
I have the same issue, one week before I go onto a Safari photoshoot. As a matter of fact, the internet is filled with 7D users having the same problem.
Mike, I do use original new Canon batteries, I have updated the fir ware to the latest version (.05) and I do not use a grip.
The symptoms are:
1) when switched on the 7D says "Can Not communicate with battery. Use this battery ?"
I will then be able to use the camera, however the battery info is not displayed
2) Howver, most of the time, even recently charged bateries are drained very rapidly (over night) even when the camera is in "off state". The camara then refuses to start at all.
Mike, this issue is too wide spread to be called a one off issue or user error. It is really an manufacturing issue. Please advise what to do.
kind regards
12-22-2013 01:53 PM
The "solutions" to this are so widespread. I have seen postings that new batteries will clear up this problem. I've also seen someone put the camera into the freezer for 20 minutes..this seemed to work (No way I was going to try that). Cleaning the copper connections..that worked for some. Removing batteries and the small watch battery...another "fix." Can't say if this was a permanent fix for them or temporarly. But for many, like myself it needed a costly repair.
Look, I love my camera..I can't complain really, I have it since mid 2010 and this is the first problem I ran into.. I've seen many who only have had the camera a few weeks before this problem started. Even one who bought it from B&H, right out of the box the issue was there. THAT has to suck.. Inconvenience, yes. I guess the bright side for them it's under warranty.
Do I fear this issue will pop up again out of nowhere, I do. I would like to know...from Canon, what is causing this (battery, faulty internal part..the firmware?) Why is it so common? I would understand a few cameras affected, but when you start typing "cannont communicate..." into Google and it autofills the rest. Then you know it's a popular problem,
Heck let us know if there is something we need to do to perhaps prevent this again.
01-16-2014 05:56 PM
01-17-2014 04:30 AM
01-17-2014 09:21 AM - edited 01-17-2014 09:21 AM
"After, as usual, no response from canon, ..."
This is a forum, it is not the place to request repair or warranty work on Canon products. They have an 800 number for you to use.
I my experience Canon has dealt with me and customers very positively. ![]()
