09-24-2015 04:57 AM
I have just updated to WIndows 10 and now cannot download images from my camera. EOS Utility activates only one action: "Monitor folder". Please help to solve this problem.
09-29-2015 12:23 AM
I thought somebody will help me, but it seems I am not on the right place!
09-29-2015 01:40 AM
09-29-2015 04:08 AM
Thank you Peter,
in meantime I've found an easy solution - From Lightroom > Import - directly from the camera with option: Copy files to my harddisk. I had never thought of this option, it is so obvious....
09-29-2015 05:13 AM
09-29-2015 05:40 AM
Yes, I just erased the images.
10-02-2015 06:52 PM
Are you saying that the EOS Utility isn't running under Windows 10?
If the EOS Utility isn't running, then it could be as simple as performing a Windows update. Just be sure to enable the option to enable update of non-Windows applications. Windows 10 does not come with Media Player. It uses a substitute.
It is an optional feature on some installs of Windows 10. Here's how to check for it on your system.
