01-27-2024 07:38 PM
I wanna use it as a webcam at 4k resolution using OBS software and what can I do to get that?
01-27-2024 08:16 PM
Most likely not. In looking through the User Manual (I suggest you do the same), there's mention about streaming in one section, but it only mentions HD (1920 x 1080) at 30 fps (29.97 fps).
There are settings for HDMI resolution where the default is "Auto" that supposedly will choose an appropriate resolution to use. But there's no explicit mention about 4K or UHD. The only explicit resolution called out via another option is HD (1080p).
01-28-2024 06:38 AM
The camera can output 4K for recording movies on an external device. So I would try this.
