09-01-2020 09:28 AM - edited 09-01-2020 10:49 AM
Greetings!
I just got the Canon 4000D from a friend and i've been trying to find the option to disable de AF brackets (AF point display) from the Live View Window but I just can't find it... Is it even possible to do it?
Hope anyone can help!
09-01-2020 02:00 PM
Try pressing [INFO] / [DISP] a couple of times. Depending on the model, the functionality is assigned to a button has one of the two different names. Cameras that have [INFO] may clear it out. I do not know what will happen on cameras with [DISP].
09-01-2020 09:36 AM
On some cameras putting the lens in manual mode will do it.
09-01-2020 10:33 AM
Even when putting the lens in manual mode, it shows this different bracket on the display and I can't disable it, even when i press the info button to scroll through what shows on the display..
This is the cleanest i could make it look
09-01-2020 02:00 PM
09-01-2020 06:05 PM - edited 09-01-2020 06:06 PM
Yeah, mine has a (DISP) button and it doesn't get rid of the bracket which is a shame.
I'll have to resort to using the EOS Webcam Utility, even if the fps is really bad
Thanks anyway!
