Battery grip options for R6 Mark II
madrav17
I recognize that the BG-E21 is intended for the 6D Mark II. Will that battery grip work with the R6 Mark II? I ask because the batteries for both bodies are compatible so I'm wondering if the same will hold true for the grips.
2 REPLIES 2
rs-eos
No. You would need a BG-R10 for your EOS R6 Mark II.
Ricky
Camera: EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L
Waddizzle
I agree with Ricky.  You must the BG-R10.  The body of the 6D Mark II has a different size, shape, and button configuration.  All of the above also applies to the battery grip.
Avatar
