08-14-2024 10:19 AM
Hello. I own a canon Mark IV and I noticed that by removing the battery door the camera does not work. The problem is that I would like to use a dummy battery and I cannot close the battery door because of the cable. How would you advise me to solve the problem? Thank you.
08-14-2024 11:05 AM
Look closely. There's a little rubber tab that you remove. It makes space for the cable.
08-14-2024 11:58 AM
I think I explained myself wrongly. I noticed that the camera does not work when the battery door is open. Is there any way to make it work even if the door is open? I have to use a dummy battery.Immagine 2024-08-14 175724.jpg
08-14-2024 12:16 PM
Unfortunately, I cannot see it. Can you help me identify it with this photo?Immagine 2024-08-14 175724.jpg
08-14-2024 04:14 PM
It's the little flap beside the battery release.
Newton
