Banding on photos
RaewynMurray
I saw some people were talking about lines on their photos.
I have some too and really want to know if they can be either removed (which I think is impossible from what I have heard) or if somewhat lessened.  I have so many to go through and would like to save some.  See photo for example.
Many thanks, RaewynLines on photos - had on silentLines on photos - had on silent
amfoto1
Trying to "rescue" this image (and others?), the links provided in some of the above responses may be very helpful.
But it would always be better to prevent the problem than to have to correct it later in post-processing (as shown at the links above).
According to the image EXIF, that was shot with a Sony A7 III, ISO 1250, 1/800 shutter speed and f/2.8 aperture (Sony FE 70-200mm f/2.8 GM OSS lens at 136mm focal length)...
I suspect it's the lighting that is causing this effect in the image. I've seen similar "banding" in LED lighting, in particular. If that's the case, a different shutter speed might have helped. Some cameras have means of "tuning" the shutter speed more precisely to match the lighting. I don't know the A7 III camera, so can't say what's possible with it.
Here it also might have something to do with using "silent" mode. I think that means the electronic shutter was used. It may have been better to use the mechanical shutter, but I really am not really sure. With many cameras, it does prevent the "rolling shutter effect" to use the mechanical shutter instead of the e-shutter. This "banding" caused by the lighting may be related to rolling shutter and solved in the same way.
I don't know if an A7 III has "Flicker Free" or "Anti-Flicker" mode like many Canon and some Nikon do... However I don't believe that would have solved this problem anyway.  What that feature does is solve overall exposure problems caused by cycling lights, such as fluorescent, sodium vapor, etc. Those types of lights actually cycle on and off very rapidly. Our eyes don't see it, but our cameras sure do! Flicker Free/Anti-Flicker detects the cycle and times the shutter release to the peak output of the lights. It's a great feature.
The only way to minimize exposure issues under those types of lights without this feature is to use a slower shutter speed that makes it more likely you'll capture the peak light output (or use a flash, to take the ambient lighting out of the equation). The off/on cycle of those lights in the US is 60 hertz, in Europe and some other parts of the world, it's 50 hertz. So using a 1/30 or 1/15 shutter speed can help... but isn't foolproof, can make for problems hand holding a steady shot, and just isn't fast enough for most moving subjects.
Flicker Free/Anti-Flicker works much better and allows a faster shutter speed that will make hand held shots possible as well as freeze subject movement. Canon's version auto detects the rate of the cycle. Nikon has it on fewer cameras, where it also can auto detect the rate, but also allows the user to manually select the 50hz or 60hz setting. I've used this feature a lot on my Canon cameras and it's a real game changer shooting sports where a fast shutter speed is necessary. In the past, without Anti-Flicker I had to take lots of extra shots because it was a good bet that around half of my images would be seriously under-exposed. Some would be recoverable in post-processing, but a lot of shots would be ruined. Now using newer cameras with Anti-Flicker I see very, very few exposure problems when shooting "under the lights".  There is a more detailed description of Canon's Anti-Flicker, with example images, here: https://www.the-digital-picture.com/Canon-Cameras/Anti-Flicker-Mode.aspx
But, once again, I don't don't know if that Sony camera has the Flicker Free/Anti-Flicker feature... And it wouldn't solve this particular problem anyway.
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2), EOS M5, some other cameras, various lenses & accessories
FLICKR
13 REPLIES 13
rs-eos
Do you have the settings that were used for this photo (knowing at least the shutter speed would be good).   A complete guess, but wondering if this was due to the stage lighting (flickering)?
Ricky
Moderator
Moderator
Hi, RaewynMurray!
So that the Community can help you better, we need to know exactly which Canon camera model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
johnrmoyer
Whiz
Whiz
If the lines were caused by LED stage lighting, I might be possible to prevent the lines by using an "anti-flicker" option on the camera or by using a different shutter speed.
If the lines are evenly spaced, it may be possible to do a fourier transform and reduce the spikes in an image editor and then do an inverse transform. It has been many years since I attempted this, but a search finds this:
https://docs.opencv.org/3.4/d2/d0b/tutorial_periodic_noise_removing_filter.html
johnrmoyer
Whiz
Whiz
Another possible example: https://dsp.stackexchange.com/questions/20061/removing-periodic-noise-from-image-using-fourier-trans...
This has an explanation of how it works and is similar to what I did many years ago:
https://imagemagick.org/Usage/fourier/
ebiggs1
Most of the time a camera captures exactly what it sees. Sometimes it is stuff that the human eye can not see. Most lights flicker but it happens so fast the eye can not see it and the person believes and sees a constantly on light.
When you set a SS that can see this flicker the camera records it. Next time try the shot with a higher SS. That may solve your issue.
EOS 1DX and many lenses.
amfoto1
Alan Myers
FLICKR
I found out from someone that it was because I had it on silent.  Trying to be nice to the people watching the shows beside me but never again.  Thank you Ricky.
Thank you, going to look into this.  It's not as bad as what I first thought but will definitely look at this and see if I can improve them more.  Thank you.
