Adjust image quality on Canon t6
Kerbpel
Hello,
I cannot figure out how to adjust the image quality on my camera. I read the manual and did it for the best quality images, but it still shows blurry when I take photos. Could anyone help?
Thank you
14 REPLIES 14
Hit the menu button. One of the wrench menus will give the option to format the card.I would also choose the low level format.
Warning! Everything on the card will be erased.
@Kerbpel wrote:
Thank you, John.
could you explain more on how to format the card? How do I do that? Thanks.
Somehow, I don't think a T6 has 2 cards. 8^)
You are correct. I mistakenly searched R6.
ebiggs1
Your problem is you need to reset the camera as you have set something incorrectly. After that do this; set the mode to P. Set ISO to 200. One shot and set the lens to AF.  WB to daylight. Now go outside on a nice day and take several shots of varying subjects especially with vertical lines.  Trees, fence, buildings, etc., but general stuff.  If all is good there is nothing wrong with your gear.  This means you need to learn how to use it.  Get up close and personal with the manual. If you don't have the manual you can d/l it from Canon.
EOS 1DX and many lenses.
