01-21-2016 03:30 PM
I know, I know - I'm an idiot and not worthy because I do shoot JPG. There, I said it! So anyhow, in June on a Saturday at noon, under a cloudless sky, could ALO or HTP help me extend the dynamic range so that the shadowed face of the base runner isn't so dark without blowing out his white pants?
Does anyone have a good source for information on how to use these two adjustments?
Thanks!
01-22-2016 04:32 PM
01-22-2016 04:48 PM
"Are the same algorithms applied in DPP that are applied in-camera?"
It may be the same routine but you are applying it to an already altered jpg. The jpg got all the settings you specified in your menus. Now you import into DPP and do additional tweaks. Sometimes it may work. Sometimes not. No matter what it can't deliver the best photo.
01-23-2016 05:29 AM
@ebiggs1 wrote:The camera can't mask anything. It can only shift the histogram one way or the other.
So, what then is ALO or HTP, and why have them? Or could one say that EV "slides" the entire histogram while ALO adjusts the left end?
...and I understand that in-camera ALO adjusts the image and is then a permanent part of the JPG - my point is only that if the ALO algorithm is the same in both the camera AND within DPP one can apply ALO to a JPG even when one hasn't turned it on in-camera. Of course if the algorithms are different - all bets are off.
01-23-2016 09:18 AM
"... you have to understand that when JPGs are saved color information is lost."
Grampy,
This is exactly my point. And this occurs each and every time you save a jpg.
01-23-2016 10:39 AM
Many thanks to both of you! I played with an old T3i image I'd taken as JPG & RAW - and I like the result from the RAW much better.
I'm going to be shooting some indoor grandkid basketball in about an hour (and the very uneven lighting in this gym really sucks!) - so I'll save the shots both ways and see what I can accomplish in post.
01-23-2016 10:47 AM
Remember, location, location and location.. Way more important that anything else.
01-23-2016 11:52 AM
@PajamaGuy wrote:Many thanks to both of you! I played with an old T3i image I'd taken as JPG & RAW - and I like the result from the RAW much better.
Be sure the Flicker compensation on your 7D Mk II is turned on. This ensures that your photos are taken when lighting is at it's peak. Many lights pulsate at the frequency of the AC electricity. Too fast for your eyes to see, but, slow enough for higher shutter speeds to be affected.
01-23-2016 08:15 AM
@PajamaGuy wrote:
I thought so, but in DPP I CAN adjust ALO in JPGs, and I do not have it turned on. My subsequent question to Canon would be, "Are the same algorithms applied in DPP that are applied in-camera?"
In DPP 3 you could not use ALO on JPGs it was greyed out. On DPP 4 you can, but, you have to understand that when JPGs are saved color information is lost.
These photos by Michael Reichmann from the website Luminous Landscape illustrate this.
The original photo as taken.
The image pushed from a JPG
The image pushed from a RAW
As you can see the color information in the blue shirt was lost as grey when it was saved into a JPG. In the RAW file the blue channel color information was retained.
01-22-2016 04:43 PM
"... I disagree with Mr. Martin that ALO must be "turned on" to be able to apply/adjust it in DPP)"
He is right. A jpg is permanently altered as the jpg it is saved. It is only filed in the data tag of a RAW. Your computer or post editor applies these tag file settings. RAW files really get very little done to their main file. You are correct in that the camera can't do anything, and likely less, that you can in PS or LR. Especially if it is a RAW file.
Personally I don't use either ALO or HTP. I much prefer to do it my self in post. My guess is none of my buds use them either.
One other word, with LR or PS or PSE the import of a RAW files is automatic. It requires nothing form you. You really won't know the difference of u/l a jpg or a RAW. There isn't any additional steps or anything that will take extra time. That only comes when you want to alter the photo. You might want to revisit using RAW.
01-22-2016 02:55 PM - edited 01-22-2016 02:56 PM
@PajamaGuy wrote:Thanks - If I could convince the moving ball, bat, and batter to hold still for three-tenths of a second, I surely would shoot HDR.
I'll shoot some RAW and see what happens!
You'll be surprised with proper post processing technique how much dynamic range modern Canon cameras like the 6D and 7D Mk II actually have when shooting RAW. You can push 3-4 stops without much effort at all, so as long as your photo is properly exposed you've got plenty of dynamic range for any outdoor sports.
