03-28-2017 06:35 PM
I have a 6 month old 80D. Randomly in use the camera turns off by itself. Sometimes itll turn back on if i press some buttons, but most of the time i have to turn it off then on again. The battery is charged but im not sure whats causing this. ANyone have any idea by any chance?
This youtube video demonstrates the same issue.
https://www.youtube.com/watch?v=I8WnYIRkoyk
Thank you so much
03-30-2017 11:21 AM - edited 03-30-2017 11:23 AM
Would it do this because the camera's buffer memory is full? Are you using a suitably high speed memory card?
You might try shooting some lower resolution video and see if that alleviates the problem. Did you format your card in the camera?
08-19-2018 11:57 AM
@lhilton1991 wrote:
Yes but it never reached thirty minutes. And also, it's not overheating because it will happen very fast. About a few minutes into recording
YES, I know this post is old.
It would only reach 30 minutes at the lower shooting resolutions. For HD video, you will run up against the 2GB files size limit, long before you hit 30 minutes.
11-29-2017 09:44 PM
Have you found a fix to this issue? I'm experiencing the same problem
11-30-2017 06:52 AM
If the camera is only six months old, and you have a one year warranty, why not just let Canon service it?
06-03-2018 08:36 PM
Hi there!
The same is happening to me. Did you solve it?
I'd aprecciate if anyone could share a solution here.
Thanks!
08-19-2018 11:59 AM
@dehschneider wrote:Hi there!
Thanks!
Are you having the camera shutdown when shooting video. There is no real “fix” for how the camera behaves when shooting video. The best fix is buy a camcorder, or an actual video camera.
09-21-2018 01:41 PM
Thanks!
Actually that didn't happen to me. At least, not yet!
My problem was when holding the camera and touching or pressing some parts of its body.
But I did solve that issue with the video that was posted above.
08-19-2018 09:08 AM
09-21-2018 01:44 PM
@ungstrup wrote:
https://www.youtube.com/watch?v=W21Y6j_o7u0
Try what he does in this video. for me it was the switch in the SD CARD that needed to be pushed in. I hope it helps!
Best regards
Thanks ungstrup!
Same was happening here. I just used a knife do push the tiny switch at the memory card door. I've used the camera several times since then and it worked perfectly fine!
10-21-2020 10:21 AM
Old question but this is an issue I was wrestling with and resolved in the following way:
First - couldn't get a clear display. Viewfinder info was showing in my output (recorded and live). Fix: use the 'info' button to turn off all viewfinder details. Usually 2 clicks. After that, be sure you're in manual focus. That will get rid of the boxes.
Second - camera kept shutting off after a few minutes. There's a feature sleeps the camera after a preset time. Go into your menu and look for the sleep/auto shutoff. Because I was not actively recording on my camera but, instead, livestreaming - it would automatically shut off after a few minutes. 4 to be precise. Disable that feature in the menu.
