80D No menu screen
jamacaulay
My 80D is not allowing me to access the menu or any of the back screen functions.  The camera takes pictures, and I can manually adjust the ISO with the wheel, but no menu access.  I want to try a factory reset but it is not possilbe without menu access.
I tried removing the battery, changing lenses, but no luck.  The lock is not on but I did toggle that as well.  Any help is appreciated.
4 REPLIES 4
Use a fully charged battery
Remove the lens
Remove the memory card
Remove the eye cup piece from the viewfinder
Put the camera into "M" manual mode
Turn on the camera
Try pressing the menu button
Now move the LCD throughout is range, pausing at different angles/postions
If you don't see any display...  Contact Canon and arrange for repair:
Canon U.S.A., Inc. | Service Request
jamacaulay
That worked, until I added a lens and snapped a picture. Back to no LCD. I already contacted Canon to set up a service
" I already contacted Canon to set up a service"
Good because that is where it belongs.
EOS 1DX and many lenses.
jamacaulay
Not sure why you felt you needed to add this comment, thank you for stating the obvious
