03-14-2013 12:41 AM
What print sizes would correspond to a Canon EOS7d full frame?
03-14-2013 08:18 AM
No idea on print size but it takes 45 M pixels in a full frame sensor to be equal to the 7D sensor. 1.6 crop sensors have approx 40% of the area a FF sensor.
03-14-2013 05:54 PM
Thanks cicopo!
03-14-2013 11:07 AM
I have no idea what you mean by 7D full frame. But here's a sizing chart. Personally I find these things overly conservative, but it'll give you an idea:
http://www.design215.com/toolbox/megapixels.php
03-14-2013 05:57 PM
Thank you Skirball, the link helps. I definitly should have taken more time to pose my question. I'm a throwback to the 35 mm days. I have always liked to print what I see in the view finder. I want it the way I composed it. So, for a Canon 7D, what sizes can I print without cropping?
Thanks in advance
03-14-2013 06:48 PM
The camera takes photos in the 2:3 ratio which translates to 2 X 3, 4 X 6, 6 X 9, 8 X 12 etc. One needs to be very aware of this when framing because it's important NOT to crop too tight when taking the shot IF it will be cropped to the much more common 8 X 10 If you shoot a family group and don't leave a bit of space at each side of them it's not going to work as an 8 X 10 without cutting someone out when cropping.
03-14-2013 06:54 PM - edited 03-14-2013 07:06 PM
You mean, what size prints will be the same ratio as the sensor?
Well, the 7D is an APS-C, which has a 3:2 ratio, which is the same as 35mm film. As far as standard sizes that would be 4x6 and its multiples: 8x12, 12x18, etc.
Edit: Oops, looks like Cicopo beat me to it.
03-15-2013 10:02 AM
This seems to be confusing to most people when they here the term “crop camera”.
All cameras are full frame. The issue only refers to the comparison of the focal length of the lens compared to the 35mm cameras of yesteryear format.
What you see in your view finder is what you are going to get. Now if you decide on a different print size, you may see some crop. But you also experienced this with 35mm film, too.
As to the lens, the focal length of the lens does not change when installed on a 1.6 crop camera. A 50 mm lens is still a 50mm lens. It “acts' like an 80 mm lens if it were compared to a 35 mm format camera. This is because of the coverage are the lens has to work with.
03-15-2013 10:40 AM
ebiggs1 is right, although today we all call "Full Frame" cameras to cameras that have sensors with 36mm x24mm which is equivalent to the 35mm film size.
Canon APS-C cameras like EOS 7D, 60D, T4i, etc., have sensor of 22.2mm x 14.8mm.
But as ebiggs1 said, either you use Full Frame DSLRs or APS-C DSLRs, you always get what you see through the View Finder (if it covers 100%, if it doesn't you get a bit more). That also applied to 35mm film cameras. Nothing new here.
03-15-2013 08:30 PM
Thank you very much HDCamTeam!
