06-18-2014 12:54 PM
My Canon EOS 7D is not turning itself off even though I have auto power off set for one minute. I think this problem began after I added a battery grip to the camera. Has anyone else had this problem?
gc
06-20-2014 01:32 AM
Is it a Canon battery grip, or a third party? I ask because I've heard of some strange things occuring when using non-OEM battery grips.
If it's a Canon battery grip, I'd try "rebooting" the camera to see if that clears the problem. Do you know how to do that? If not, it's pretty easy. Just remove all the batteries (including the date/time battery), turn the camera on and press the shutter release button once. It won't fire, but this will drain all remaining power from the system and force the camera to reboot. Put the batteries back in and check to see if the date/time needs to be reset... if so, you got a good reboot. (You might have to reset some of your other settings, too.)
Hopefully that helps. Otherwise, I'm at a loss.
Alan Myers
San Jose, Calif., USA
FLICKR & PRINTROOM
06-20-2014 03:43 PM - edited 06-24-2014 04:12 AM
@aquadiver wrote:My Canon EOS 7D is not turning itself off even though I have auto power off set for one minute. I think this problem began after I added a battery grip plr to the camera. Has anyone else had this problem?
gc
I too have the same issue. I am really confused about what to do. Please let me know if you find a viable solution. 🙂
06-26-2014 07:46 AM
Update: First, it is a Canon battery grip. I was able to determine it was not the cause of the problem, because the problem persisted even without the grip attached.
I e-mailed Canon tech support, who at first misunderstood my question and thought I just had a rapid battery discharge issue. They suggested rebooting to see if that solved the discharge problem. It did not. I already knew why the battery was draining so fast, because the camera wouldn't turn itself off. So they recommended I send it to Canon factory service. Which I did.
Turns out the problem was a bad main circuit board, and the solution was to replace the circuit board. That ain't cheap, but it ws necessary. I thought about not getting it replaced and just trying to learn to turn the camera off manually more often, but I figured if the circult board was bad something else would randomly go wrong eventually.
So I expect the camera back today, and I expect it to work just fine. I should know better about expectation, but there you are.
Hope this is helpful to someone else....
gc
04-29-2024 11:34 PM
i had trouble with my canon TR 4500 not auto turning off. To fix this i used the on-screen setting and did a firmware update. after-which my printer restarted and auto turn off now works. Hope this helps!
