7D MKII - IPB-Lite Data Rate
peter-ops
Hello,
Does anybody know the actual maximum Data Rate for the new IPB-Lite option?  I need the info for the Data Rate Calculator we use at work. I havent been able to get my hands on any footage as of yet, so the maximum Data Rate would give me a good place to start.
Even better,  if anyone has some test material they would be willing to send me I would be really grateful.
Thanks a bunch folks
2 REPLIES 2
PaulSoebekti
Enthusiast
Hi Peter:
Are you enquiring about data rates for CF and/or SD cards for MP4? If so, CF cards must be 10MB/s or faster while SD cards 4MB/s or faster.
Paul
Hi Paul,
Thankyou for your response. I was enquiring about the actual compression applied to the .MP4s when the IPB-Lite setting is used to encode the file. Although I understand H264 is going to be a variable bit-rate, im curious to know what the maximum data rate would be.  For example, I believe the ALL-I mode caps at 90Mbps.  Im using this information to enter into a Data Rate Calculator so people can calculate the amount of data they have shot or will shoot using this compression.
If you could help that would be great, otherwise I thankyou for your response.
Regards
Pete
