02-14-2015 09:57 PM
Hi- I have a 70D and was out shooting a basketball game, when out of nowhere a big streak of light started showing up in every frame. I was wondering if anyone had a similiar situation and knows a solution?
Thanks
09-14-2015 02:06 AM
09-14-2015 07:36 AM
@Dora wrote:
I had the exact thing happen to me last week! Was taking lots of shots, then the streak suddenly appeared! My camera is almost two years old.
Earlier examples mentioned in this thread apparently turned out to be shutter failure, not a light leak. That makes perfect sense, of course; a light leak would usually be expected to show up immediately, a broken shutter only after some amount of wear.
Neither problem is a fix-it-yourself matter. If you want to keep using the camera, you should probably consign it to Canon's expensive, but highly regarded, service organization.
09-14-2015 09:48 AM
I had enough Canon equipment that I was able to enroll in Canon Professional Services, which is about $100 per year. I sent the camera in for maintenance, and they were able to fix the stuck shutter issue at no extra charge.
It also allows me to send in my other equipment for maintenance, and "borrow" some lenses and bodies to experiment with, at no extra charge other than shipping.
I would hightly recommend trying to enroll.
09-14-2015 10:02 AM
@shilchey wrote:I had enough Canon equipment that I was able to enroll in Canon Professional Services, which is about $100 per year. I sent the camera in for maintenance, and they were able to fix the stuck shutter issue at no extra charge.
Been there; done that. I haven't been sorry.
09-14-2015 10:21 AM
CPS is fantastic. I just completed sending in all the stuff I intend on keeping for a C&C. I think this is my last Gold year. I just don't shoot all that much anymore.
I doubt you were able to get a Gold membership with just a 70D? What else do you have? ![]()
I would encourage all serious amateurs and pros or aspiring pros to join. Regular Canon service will work for most people.
09-14-2015 10:56 AM
For those that don't know, to enroll in CPS you have to have a certain number of "points" which are based off of individual pieces of Canon equipment.
I won't pretend to remember what the minimum point levels are for enrollment, but it won't take much searching to find out.
I discovered that camera bodies aren't worth that many points. What really racks up the count are lenses, and flashes.
Beside the 70d body, I have
70-200 / f4
24-70 /f2.8
50 /f1.4
70-300 /f3.5-5.6
1 580exii
2 430ex
While I was really worried when I entered the 70d on the web page, and I received credit for only a couple of points, I had more than enough points once I added in everything else.
09-14-2015 03:54 PM
Nice outfit. ![]()
"I discovered that camera bodies aren't worth that many points."
Hmmm, you must have never entered a new 1D Mk IV or 1Ds Mk III ? Or as of today a 1Dx? They are point getters!
10-10-2016 09:49 PM
did you get this repaired? how much did it cost and how long did it take?
@azdew wrote:
I am having the same issue. Same overexposed area, same shape, same location. Changed lens and still happened. It happened on 2/19/15. My shots look exactly like the sample posted above. I dropped it off for repair. Waiting for a quote.
