04-11-2018 05:01 PM
I've noticed when setting my 70D to shoot at its full speed 7 fps that I don't always get that frame rate constantly. The frame rate seems to vary depending on which lens I have fitted and also when the shot is under expsosing. EG on shutter priority at 200th and f3,5 and corectly exposed I get the full 7 fps, however aim the camera slightly differently so that the shot is now under exposing but still with all the same settings the fps is noticeably slower. I have no idea why, has anyone else come across this and if so what the cause and fix was\is
04-12-2018 06:39 AM
04-12-2018 12:28 PM
Turn off lens corrections. I am guessing that the lenses that are currently working have no correction data registered with the camera.
04-12-2018 08:35 PM
You might get better results saving shots as JPEGs when you use continuous shooting. It takes less time to write a smaller JPEG file than a larger RAW file.
